Api session event editor functionoverride reset
API Endpoint: api/session/event/editorfunctionoverride/reset/
Description: Reset a Function
0 REQUIRED (FUNCTION Integer ID) Function
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/reset/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/reset/", options)
