Api session event editor area generate inundation areas
Revision as of 15:28, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/generate_inundation_areas/
Description: Generate Water Inundation Area(s) with the Inundation Level Attribute set to the provided value
0 REQUIRED (Floating point number) Inundation Level (m)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '16'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '62'
JavaScript example POST
 body: '16'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/", options)
