Api session items measures
Revision as of 13:20, 3 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/measures/
Edit items with events described at Api session event editor measure.
Default Query:
https://engine.tygron.com/api/session/items/measures/?token=API_TOKEN
Example Response:
  "actualHeightChangeM3" : null,
  "buildingIDs" : [ 1405 ],
  "buildingPermitProcessed" : null,
  "center" : {
    "type" : "Point",
    "coordinates" : [ 659086.4055532492, 6799091.1227987455, 55.402 ]
  "clientActionEvents" : { },
  "confirmationsRequired" : false,
  "constructionCostsFixed" : -1.0,
  "constructionCostsM3" : 0.0,
  "custom" : false,
  "dependencyIDs" : [ ],
  "description" : "",
  "geoTiffSpatials" : [ ],
  "gridSpatials" : [ ],
  "id" : 0,
  "imageName" : "measure.png",
  "imageVersion" : 0,
  "incomeFixed" : 0.0,
  "landOwnerPermissions" : { },
  "leveeSpatials" : [ ],
  "name" : "Measure",
  "ownerID" : 2,
  "serverActionEvents" : { },
  "sourceIDs" : [ ],
  "state" : "NOTHING",
  "terrainSpatials" : [ {
    "id" : 1,
    "innerHeight" : 49.559317009580646,
    "innerPolygon" : {
      "type" : "MultiPolygon",
      "coordinates" : [ [ [ [ 659142.0614489131, 6799231.181467466 ], [ 659142.7646998417, 6799263.655208195 ], [ 659061.5757606464, 6799265.410856503 ], [ 659060.8741338538, 6799232.937108732 ], [ 659142.0614489131, 6799231.181467466 ] ] ] ]
    "measureEditType" : "WATER",
    "outerPolygon" : {
      "coordinates" : [ [ [ [ 659041.5063109348, 6799223.619708879 ], [ 659155.0675307526, 6799218.219617132 ], [ 659158.153389331, 6799283.110281363 ], [ 659044.592169513, 6799288.5104164 ], [ 659041.5063109348, 6799223.619708879 ] ] ] ]
    "relative" : false,
    "terrainTypeID" : 3
    "id" : 2,
    "innerHeight" : 0.0,
    "innerPolygon" : {
      "coordinates" : [ ]
    "measureEditType" : "FLATTEN",
    "outerPolygon" : {
      "coordinates" : [ ]
    "relative" : false,
    "terrainTypeID" : 1
  "upgradeSpatials" : [ ],
  "version" : 5
  "buildingIDs" : [ 1410, 1411, 1412, 1413, 1414, 1415, 1416, 1417, 1418, 1419 ],
  "center" : {
    "type" : "Point",
    "coordinates" : [ 659256.3616506538, 6799141.129437042, 58.377 ]
  "custom" : false,
  "description" : "",
  "id" : 1,
  "imageVersion" : 0,
  "name" : "Measure (2)",
  "ownerID" : 2,
  "sourceIDs" : [ ],
  "terrainSpatials" : [ ],
  "version" : 4
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/measures/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/measures/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/measures/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/measures/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/measures/?crs=LOCAL&token=API_TOKEN
Bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/measures/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/measures-foo/?crs=3857&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/measures/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/measures/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/measures/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/measures/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/measures/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/measures/?f=JSON&token=API_TOKEN
GEOJSON:
https://engine.tygron.com/api/session/items/measures/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/measures/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/measures/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/measures/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/measures/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/measures/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/measures/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/measures/?f=ZIPSMILE&token=API_TOKEN
Api Model ActionType
API Enumeration description of ActionType
Name Description
CONSTRUCTION_PLAN
CONSTRUCTION_PLAN_CANCEL
Api Model GeoTiffSpatial
API Model description of GeoTiffSpatial
Name Type Description
autoMP boolean
geoTiffIDs int[] Geo Tiffs ID
id int
multiPolygon MultiPolygon MultiPolygon
terrainTypeID int
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model GridSpatial
API Model description of GridSpatial
autoMP boolean
id int
overlayIDs int[] Overlays ID
terrainTypeID int
Api Model LeveeSpatial
API Model description of LeveeSpatial
angleOverride double
heightOverride double
id int
isRelativeOverride Boolean
leveeID int Levee ID
sidePolygon MultiPolygon MultiPolygon
topPolygon MultiPolygon MultiPolygon
Api Model LineString
API Model description of LineString
Api Model MapMeasure
API Model description of MapMeasure
actualHeightChangeM3 double
buildingIDs int[] Buildings ID
buildingPermitProcessed Set
center Point Point
clientActionEvents Map<ActionType,java.util.List<nl.tytech.data.core.item.CodedEvent>> Map<ActionType,java.util.List<nl.tytech.data.core.Item.CodedEvent>>
confirmationsRequired boolean
constructionCostsFixed double
constructionCostsM3 double
custom boolean
dependencyIDs int[] Measures ID
description String
geoTiffSpatials GeoTiffSpatial[] GeoTIFFSpatial[]
gridSpatials GridSpatial[] GridSpatial[]
id int
imageName String
imageVersion int
incomeFixed double
landOwnerPermissions Map<int,Boolean>
leveeSpatials LeveeSpatial[] Leveespatial[]
name String
ownerID int Stakeholder ID
serverActionEvents Map<ActionType,java.util.List<nl.tytech.data.core.item.CodedEvent>> Map<ActionType,java.util.List<nl.tytech.data.core.Item.CodedEvent>>
sourceIDs int[] Sources ID
state TimeState Timestate
terrainSpatials TerrainSpatial[] Terrainspatial[]
upgradeSpatials UpgradeSpatial[]
version int
Api Model Measure
API Model description of Measure
custom boolean
description String
id int
imageName String
imageVersion int
incomeFixed double
name String
version int
Api Model MeasureEditType
API Enumeration description of MeasureEditType
Name Description
BUILDING
RAISE
FLATTEN
WATER
UPGRADE
LEVEE
GEOTIFF
GRID
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model TerrainSpatial
API Model description of TerrainSpatial
id int
innerHeight double
innerPolygon MultiPolygon MultiPolygon
innerPrep PreparedGeometry
measureEditType MeasureEditType MeasureEditType
outerPolygon MultiPolygon MultiPolygon
outerPrep PreparedGeometry
outerRings LineString[]
relative boolean
terrainTypeID int
Api Model TimeState
API Enumeration description of TimeState
Name Description
NOTHING
WAITING_FOR_DATE
REQUEST_PLOT_OWNER_APPROVAL
REQUEST_ZONING_APPROVAL
REQUEST_CONSTRUCTION_APPROVAL
CONSTRUCTION_APPROVED
CONSTRUCTION_DENIED
PENDING_CONSTRUCTION
CONSTRUCTING
READY
PENDING_UPGRADE
WAITING_FOR_DEMOLISH_DATE
REQUEST_DEMOLISH_ZONING_APPROVAL
REQUEST_DEMOLISH_APPROVAL
DEMOLISH_APPROVED
DEMOLISH_DENIED
PENDING_DEMOLISHING
DEMOLISHING
DEMOLISH_FINISHED
Api Model UpgradeSpatial
API Model description of UpgradeSpatial
id int
upgradeID int Upgrade Type ID
