Heat Stress Module benchmarks
Revision as of 08:02, 14 October 2026 by Frank@tygron.nl (talk | contribs) (→Point Measurement Analysis)
The DPRA Heat stress report includes reference information on the city of Wageningen on 02-08-2013. This data is relevant as it correlates with actual measurements for Wageningen. The PET measurements for this exceptionally hot day are comparable to the default 01-07-2015 reference case for Wageningen.
The performed benchmark has an average difference below 0.68% for the selected measurement points.
Results
The PET Benchmark result overlays can be seen below:
  • PET daytime map for August 2, 2013 12 UTC with the meteorology of the reference station Herwijnen from the DPRA Heat stress report
  • PET daytime map for August 2, 2013 12 UTC with the weather data from the reference station Herwijnen as calculated by the Tygron Platform
Several points have been compared for results. Points were selected where spatial conditions (e.g., foliage and vegetation fraction) are similar for both PET calculations.
Location of the measurement points in blue.
id Wageningen PET Tygron PET Difference (%)
01 46.12 46.13 0.022
02 47.44 48.04 1.26
03 47.11 47.52 0.87
04 44.70 44.99 0.65
05 40.53 40.48 0.12
06 38.69 38.67 0.05
07 42.52 42.45 0.16
08 44.87 44.03 1.87
09 43.62 43.02 1.38
10 46.79 46.58 0.45
11 38.70 38.79 0.23
12 44.40 44.00 0.90
13 46.34 46.29 0.11
14 45.58 45.77 0.42
15 39.05 39.42 0.95
16 38.22 38.28 0.16
17 43.23 43.88 1.50
18 46.34 46.49 0.32
19 45.59 44.84 1.65
20 46.21 45.96 0.54
Average 0.68
The average difference in calculated PET for these spatially similar points is 0.68%.
Setup
Weather data from weatherstation Herwijnen has been used for this test case. The used values are:
Variable Value
Date 02-08-2013
Hour of day 14
Sun altitude 55.5
Sun azimuth 186.9
Sun daily motion factor 0.063
Humidity (%) 56
Sun radiation (W/m2) 774
Temperature (°C) 31.7
Wind speed (m/s) 4
Wind direction (°) 140
Daily min. temperature (°C) 18.9
Daily max. temperature (°C) 34.1
Daily avg. radiation (W/m2) 455
Daily avg. wind speed 3.17
The foliage height will be defined by a GeoTIFF. See the images (overview and zoomed in east-south-east corner) below:
  • Overview of the foliage height in Wageningen
  • Zoomed in on the foliage height in Wageningen, east-south-east corner of the overview
Calculation time
The calculation time of the PET overlay of 1 timeframe on a 1x1 meter grid for a 4x4km area of Wageningen is approximately 5 seconds.
