Skill
An LLM skill item is a structured configuration document that defines what a AI Agent is allowed to do, how it should behave, and which parameters control its generation. Think of it as the "job description" for an AI assistant: instead of shipping a one-size-fits-all chatbot, you add a Skill that scopes the agent's capabilities.
Skills are available in version Version 2026.3.0+
Properties
In the Tygron Platform, skills have three parts:
  • Skill name: Use /indicator-excel-sheet to add create an Excel Sheet for the indicator
  • Skill description: Used to determine whether to use the skill or not. Should be 1 or 2 sentences max.
  • Skill content: The actual skill contents. Subdivided into parts, for example:
    • Purpose
    • Requirements
    • Preferences
    • Procedure
Skill referencing
A skill can reference an other skill in its content by prepending the name with a '/'. For example, the skill heat-stress-indicator can reference /indicator-excel-sheet to indicate what skill should be used to create a new heat-stress indicator.
