Indicator Chat tutorial
Prerequisites
  • This tutorial will take approximately ~30 minutes.
  • This tutorial relies on base knowledge about the editor interface. If you have not yet followed the tutorials related to those subjects please do so first.
  • This tutorial can be followed with any project with write access but is designed in the Demo Dxf Import project.
Preparations
  • Start the Demo Dxf Import project.
Save as
In the case the project Demo Dxf Import is used, as suggested above, for this tutorial it is required to save the project to your domain. First open this project in the editor. Once opened, select File in the ribbon and select the option Save as. Provide a new name and save this project to your domain. This grants write access for the project, which is currently required for adding Excel Files to your project. These excel files are used to store calculation logic of Indicators.
Introduction AI Agents
In the Editor you can interact with several predefined AI Agents via Chat Channels. In this tutorial we will use the Project Coder agent to implement a default Heat Stress Indicator. Once designed it can be further tweaked using additional instructions. Note that with AI correct answers and implementations are not guaranteed!
Project Code
To start creating an indicator with the Project Coder, we will have to open the Chat Channel of this AI Agent. Select Community in the ribbon bar, hover over Chats and select Project Coder. This opens the Chat Panel with the selected agent.
Editor → Community (Ribbon tab) → Chats (Ribbon bar) → Project Codert (Dropdown)
Location of Chats in the Community tab in the ribbon of the Editor.
Create a Heat Stress Indicator
In this example, we can simply instruct the agent with the following text
Add a heat stress indicator
Click on the "Send" button to send this instruction to the agent.
Tutorial completed
Congratulations. You have now completed this tutorial. In it, you have learned how to use the Chat functionality to interact with AI Agents..
