Api session event editor building query
Revision as of 15:22, 30 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/query/
Description: Execute a single TQL Query. Use the Session/query Endpoint for multiple statements or detailed API usage information.
0 REQUIRED (String) TQL Query Statement
1 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value for update queries (optional)
200 Object (Object)
curl 'https://engine.tygron.com/api/session/event/editorbuilding/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TQL Query Statement"'
JavaScript example POST
 body: '"TQL Query Statement"'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/query/", options)
