Api session items netlines
Revision as of 09:52, 23 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/netlines/
Edit items with events described at Api session event editor netline.
Default Query:
https://engine.tygron.com/api/session/items/netlines/?token=API_TOKEN
Example Response:
  "attributes" : null,
  "endNodeID" : 1,
  "functionID" : 0,
  "id" : 0,
  "maquetteOverride" : null,
  "name" : "NetLine 0",
  "sourceIDs" : [ ],
  "startNodeID" : 0,
  "version" : 1
  "endNodeID" : 58,
  "functionID" : 0,
  "id" : 1,
  "name" : "NetLine 1",
  "sourceIDs" : [ ],
  "startNodeID" : 35,
  "version" : 2
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/netlines/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/netlines/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/netlines/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/netlines/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/netlines/?crs=LOCAL&token=API_TOKEN
Bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/netlines/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/net_lines-foo/?crs=3857&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/netlines/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/netlines/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/netlines/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/netlines/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/netlines/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/netlines/?f=JSON&token=API_TOKEN
GEOJSON:
https://engine.tygron.com/api/session/items/netlines/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/netlines/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/netlines/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/netlines/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/netlines/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/netlines/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/netlines/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/netlines/?f=ZIPSMILE&token=API_TOKEN
Api Model NetLine
API Model description of NetLine
Name Type Description
attributes Map<String,double[]>
endNodeID int Net Node ID
functionID int Net Function ID
id int
maquetteOverride Map<String,double[]>
name String
sourceIDs int[] Sources ID
startNodeID int Net Node ID
version int
