Api session event editor setting set ai editing
Revision as of 09:52, 23 September 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorsetting/set_ai_editing/ Description: Set if AI Agents are allowed to edit Project data. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (true, false) | True for allow, false to disable editing | true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 204 | No Content |- | 300-600 | Codes Overview |} ===Example POST=== Curl example POST <syntaxhighlight lang="te...")
0 REQUIRED (true, false) True for allow, false to disable editing true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_ai_editing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'
JavaScript example POST
 body: 'true'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_ai_editing/", options)
