Api session event editor skill set description
Revision as of 13:31, 22 September 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorskill/set_description/ Description: Set Description {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (SKILL Integer ID or multiple integer values in array [1, 2, 3]) | Skills | |- | 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | Boolean (Content was updated) |- | 300-600 | Code...")
0 REQUIRED (SKILL Integer ID or multiple integer values in array [1, 2, 3]) Skills
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorskill/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorskill/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'
JavaScript example POST
 body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorskill/set_description/", options)
