Api session items indicators
Revision as of 08:07, 22 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/indicators/
Edit items with events described at Api session event editor indicator.
Default Query:
https://engine.tygron.com/api/session/items/indicators/?token=API_TOKEN
Example Response:
  "absolute" : true,
  "attributes" : null,
  "calcTimeMS" : 0,
  "currentExplanation" : "Simple dummy Indicator",
  "description" : "",
  "exactNumberValues" : { },
  "exactTextValues" : { },
  "excelID" : 12,
  "id" : 0,
  "imageName" : "excel.png",
  "imageVersion" : 0,
  "isActive" : true,
  "mapTypeValues" : {
    "CURRENT" : 0.0,
    "MAQUETTE" : 0.0
  "maquetteExplanation" : "",
  "maquetteOverride" : null,
  "name" : "Indicator",
  "parentID" : -1,
  "shortName" : "Indicator",
  "sortIndex" : 51,
  "stakeholderID" : -1,
  "targetDescriptions" : [ ],
  "targets" : { },
  "updateTiming" : "BEFORE",
  "version" : 10,
  "warnings" : ""
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/indicators/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/indicators/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/indicators/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/indicators/count/?token=API_TOKEN
Specific Item:
https://engine.tygron.com/api/session/items/indicators/{itemID}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/indicators/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/indicators/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/indicators/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/indicators/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/indicators/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/indicators/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/indicators/?f=ZIPSMILE&token=API_TOKEN
Api Model Indicator
API Model description of Indicator
Name Type Description
absolute boolean
attributes Map<String,double[]>
calcTimeMS long
currentExplanation String
description String
exactNumberValues Map<MapType,double> Map<Map Type,double>
exactTextValues Map<MapType,String> Map<Map Type,String>
excelID int Excel Sheet ID
excelUpdated boolean
id int
imageName String
imageVersion int
isActive boolean
mapTypeValues Map<MapType,double> Map<Map Type,double>
maquetteExplanation String
maquetteOverride Map<String,double[]>
name String
parentID int Indicator ID
shortName String
sortIndex int
stakeholderID int Stakeholder ID
targetDescriptions String[]
targets Map<int,double[]>
updateTiming Timing
version int
warnings String
Api Model MapType
API Enumeration description of MapType
Name Description
CURRENT
MAQUETTE
Api Model Timing
API Enumeration description of Timing
Name Description
BEFORE
AFTER
