Api session items panels
API Endpoint: /api/session/items/panels/
Edit items with events described at Api session event editor panel.
Default Query:
https://engine.tygron.com/api/session/items/panels/?f=JSON&token=API_TOKENExample Response:
"answers" : [ ],
"attributes" : {
"ATTENTION" : [ 1.0 ],
"POPUP_TYPE" : [ 0.0 ],
"SCALE" : [ 1.0 ],
"VISIBLE" : [ 1.0 ],
"VISIBLE_TIMEFRAME" : [ 0.0 ]
"calcTimeMS" : 0,
"contentID" : null,
"contentMapLink" : null,
"excelID" : 1,
"height" : null,
"id" : 0,
"layoutX" : null,
"layoutY" : null,
"maquetteOverride" : null,
"name" : "Excel Panel",
"overlayID" : -1,
"overrideDefaultAnswerID" : -1,
"parentID" : null,
"point" : null,
"polygons" : null,
"stakeholderID" : -1,
"text" : "Hello World!",
"type" : "EXCEL_PANEL",
"updateTiming" : "BEFORE",
"version" : 1,
"warnings" : "",
"width" : null
"answers" : [ ],
"attributes" : {
"COLOR" : [ -6704129.0 ],
"POPUP_TYPE" : [ 7.0 ],
"SCALE" : [ 1.0 ],
"calcTimeMS" : 0,
"contentID" : null,
"height" : null,
"id" : 1,
"layoutX" : null,
"layoutY" : null,
"name" : "Text Panel",
"overlayID" : -1,
"parentID" : null,
"point" : {
"type" : "Point",
"coordinates" : [ 658907.9990757483, 6798948.801026824 ]
"text" : "Point of interest",
"type" : "TEXT_PANEL",
"version" : 2,
"warnings" : "",
"width" : null
} ]Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/panels/?version=100&token=API_TOKENGet Queries
Attributes:
https://engine.tygron.com/api/session/items/panels/attributes/?token=API_TOKENMax version:
https://engine.tygron.com/api/session/items/panels/version/?token=API_TOKENCount:
https://engine.tygron.com/api/session/items/panels/count/?token=API_TOKENSpecific Item:
https://engine.tygron.com/api/session/items/panels/{itemID}/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/panels/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/panels/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/panels/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/panels/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/panels/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/panels/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/panels/?f=ZIPSMILE&token=API_TOKENApi Model Answer
API Model description of Answer
| Name | Type | Description |
| clientEvents | CodedEvent[] | |
| contents | String | |
| events | CodedEvent[] | |
| id | int | |
| selected | boolean |
Api Model CodedEvent
API Model description of CodedEvent
| id | int | |
| parameters | Object[] |
Api Model ExcelPanel
API Model description of ExcelPanel
| answers | Answer[] | Answer (Panel)[] |
| attributes | Map<String,double[]> | |
| calcTimeMS | long | |
| contentID | int | |
| contentMapLink | MapLink | Maplink |
| excelID | int | Excel Sheet ID |
| height | double | |
| id | int | |
| layoutX | double | |
| layoutY | double | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| overlayID | int | Overlay ID |
| overrideDefaultAnswerID | int | |
| parentID | int | |
| point | Point | Point |
| polygons | MultiPolygon | MultiPolygon |
| stakeholderID | int | Stakeholder ID |
| text | String | |
| type | PanelType | PanelType |
| updateTiming | Timing | |
| version | int | |
| warnings | String | |
| width | double |
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model GlobalPanel
API Model description of GlobalPanel
| globalIDs | int[] | Globals ID |
| height | double | |
| id | int | |
| name | String | |
| version | int | |
| width | double |
Api Model LogicPanel
API Model description of LogicPanel
| contentID | int | |
| height | double | |
| id | int | |
| name | String | |
| parentID | int | |
| text | String | |
| version | int | |
| width | double |
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | MultiPolygon |
| coordinates | double[][][][] | array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
Api Model Panel
API Model description of Panel
| height | double | |
| id | int | |
| name | String | |
| version | int | |
| width | double |
Api Model PanelType
API Enumeration description of PanelType
| Name | Description |
| GLOBAL_PANEL | |
| EXCEL_PANEL | |
| WEB_PANEL | |
| TEXT_PANEL | |
| TEMPLATE_EXCEL_PANEL | |
| TEMPLATE_TEXT_PANEL |
Api Model Point
API Model description of Point
| type | String | Point |
| coordinates | double[] | x, y, (optional) z |
Api Model Relation
API Enumeration description of Relation
| OWNER | |
| CONSTRUCTOR | |
| DEMOLISHER | |
| PERMITTER | |
| SENDER | |
| RECEIVER | |
| NETOWNER | |
| BORDER_A | |
| BORDER_B | |
| BUILDING | |
| WEATHER | |
| PARENT | |
| RESULT_PARENT | |
| CONTENT |
Api Model TemplateExcelPanel
API Model description of TemplateExcelPanel
| attribute | String | |
| autoApplied | boolean | |
| contentID | int | |
| height | double | |
| id | int | |
| mapLink | MapLink | Maplink |
| name | String | |
| parentID | int | |
| relation | Relation | Relation |
| text | String | |
| useOwner | boolean | |
| version | int | |
| width | double |
Api Model TemplateTextPanel
API Model description of TemplateTextPanel
| contentID | int | |
| height | double | |
| id | int | |
| name | String | |
| parentID | int | |
| text | String | |
| version | int | |
| width | double |
Api Model TextPanel
API Model description of TextPanel
| contentID | int | |
| height | double | |
| id | int | |
| name | String | |
| parentID | int | |
| text | String | |
| version | int | |
| width | double |
Api Model Timing
API Enumeration description of Timing
| BEFORE | |
| AFTER |
Api Model WebPanel
API Model description of WebPanel
| height | double | |
| id | int | |
| name | String | |
| url | String | |
| version | int | |
| width | double |
