Iteration
An iteration is a run of all steps of the Simulation Core.
By default a project is configured with 1 iteration.
The amount of Iterations performed is configured using the ITERATIONS Setting.
Iteration Overlay
The Iteration Overlay is an Overlay that collects results from its Prequel for only particular Iterations, configured using its MODULUS attribute.
Activity per Iteration
The Attribute ITERATION_ACTIVE can be added to a Grid Overlay. The attribute can be configured with an array of values, where each value represents an iteration in which this Grid Overlay is active. When a Grid Overlay is set to inactive, this attribute has no effect.
  • The configuration of multiple iterations enables the Iteration Loop option in the Water Overlay Wizard's Output Overlays step.
