How to import KNMI weather data into Microsoft Excel
Revision as of 09:45, 15 July 2026 by Maxim@tygron.com (talk | contribs)
To process KNMI Weather data in the Tygron Platform, import the text file into Microsoft Excel following the steps for your Office version.
Activate the text import wizard in Office 2019
Newer versions of Excel use a simplified text/csv import that may not correctly interpret data as numbers. Use the legacy Text Import Wizard instead.
Select Data > Get Data > Legacy Wizards > From Text (Legacy)
How to activate the legacy Text Import Wizard in Excel:
  1. Select File > Options
  2. Select Data from the Excel options
  3. Under Show legacy data import wizards, select From Text (Legacy)
  4. Select OK
When the legacy Text Import Wizard is activated, it can be found under: Data > Get Data > Legacy Wizards > From Text (Legacy). When prompted, in the Import File dialog, select the KNMI file you need.
Text Import Wizard
How to import the text file in Excel:
  1. As the data in the KNMI files is separated by commas, select Delimited. It can also be convenient to enter '32' as the line number to Start import at row, to skip the header texts from the file and start at the top of the table of actual values.
  2. On this panel, select the comma as separator.
  3. Select Finish to proceed
When the import is done, the KNMI data should appear on the workbook. Successful conversion is indicated by numbers being right-aligned; text aligns to the left by default.
Activate the text import wizard in older Office versions
Select Data > Get External Data > From Text. In the Import File dialog, select the KNMI file you need.
Reference to Microsoft support about text import in other Office versions: Text Import Wizard
