How to remove a WFS link from your project
WFS links you have added yourself can be removed from your project.
Editor → Current Situation (Ribbon tab) → Geo import (Ribbon bar) → Show Project Sources (Dropdown) → The Project Source to edit (Left panel)
How to remove a WFS Connection:
- Select the desired connection you wish to remove
- Click on the button 'Remove' in the bottom left corner
- The project sources created and used by the Tygron Platform cannot be removed.
- Unused WFS links do not affect your data, so removing them is not required. However, especially when working with multiple users in the same project, or when creating a template project, keeping the WFS links limited to valid and relevant options is recommended.
