Api session items panels
API Endpoint: /api/session/items/panels/
Edit items with events described at Api session event editor panel.
Default Query:
https://engine.tygron.com/api/session/items/panels/?f=JSON&token=API_TOKEN
Example Response:
  "answers" : [ ],
  "attributes" : {
    "ATTENTION" : [ 1.0 ],
    "POPUP_TYPE" : [ 0.0 ],
    "SCALE" : [ 1.0 ],
    "VISIBLE" : [ 1.0 ],
    "VISIBLE_TIMEFRAME" : [ 0.0 ]
  "calcTimeMS" : 0,
  "contentID" : null,
  "contentMapLink" : null,
  "excelID" : 1,
  "height" : null,
  "id" : 0,
  "layoutX" : null,
  "layoutY" : null,
  "maquetteOverride" : null,
  "name" : "Excel Panel",
  "overlayID" : -1,
  "overrideDefaultAnswerID" : -1,
  "parentID" : null,
  "point" : null,
  "polygons" : null,
  "stakeholderID" : -1,
  "text" : "Hello World!",
  "type" : "EXCEL_PANEL",
  "updateTiming" : "BEFORE",
  "version" : 3,
  "warnings" : "",
  "width" : null
  "answers" : [ ],
  "attributes" : {
    "COLOR" : [ -6704129.0 ],
    "POPUP_TYPE" : [ 7.0 ],
    "SCALE" : [ 1.0 ],
  "calcTimeMS" : 0,
  "contentID" : null,
  "height" : null,
  "id" : 1,
  "layoutX" : null,
  "layoutY" : null,
  "name" : "Text Panel",
  "overlayID" : -1,
  "parentID" : null,
  "point" : {
    "type" : "Point",
    "coordinates" : [ 658907.9990757483, 6798948.801026824 ]
  "text" : "Point of interest",
  "type" : "TEXT_PANEL",
  "version" : 5,
  "warnings" : "",
  "width" : null
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/panels/?version=100&token=API_TOKEN
Get Queries
attributes:
https://engine.tygron.com/api/session/items/panels/attributes/?token=API_TOKEN
max version:
https://engine.tygron.com/api/session/items/panels/version/?token=API_TOKEN
count:
https://engine.tygron.com/api/session/items/panels/count/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/panels/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/panels/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/panels/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/panels/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/panels/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/panels/?f=ZIPSMILE&token=API_TOKEN
Api Model Answer
API Model description of Answer
Name Type Description
clientEvents CodedEvent[]
contents String
events CodedEvent[]
id int
selected boolean
Api Model CodedEvent
API Model description of CodedEvent
id int
parameters Object[]
Api Model ExcelPanel
API Model description of ExcelPanel
answers Answer[] Answer (Panel)[]
attributes Map<String,double[]>
calcTimeMS long
contentID int
contentMapLink MapLink Maplink
excelID int Excel Sheet ID
height double
id int
layoutX double
layoutY double
maquetteOverride Map<String,double[]>
name String
overlayID int Overlay ID
overrideDefaultAnswerID int
parentID int
point Point Point
polygons MultiPolygon MultiPolygon
stakeholderID int Stakeholder ID
text String
type PanelType PanelType
updateTiming Timing
version int
warnings String
width double
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model GlobalPanel
API Model description of GlobalPanel
globalIDs int[] Globals ID
height double
id int
layoutX double
layoutY double
name String
point Point Point
version int
width double
Api Model LogicPanel
API Model description of LogicPanel
calcTimeMS long
contentID int
height double
id int
layoutX double
layoutY double
name String
parentID int
point Point Point
text String
updateTiming Timing
version int
warnings String
width double
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Panel
API Model description of Panel
height double
id int
layoutX double
layoutY double
name String
point Point Point
version int
width double
Api Model PanelType
API Enumeration description of PanelType
Name Description
GLOBAL_PANEL
EXCEL_PANEL
WEB_PANEL
TEXT_PANEL
TEMPLATE_EXCEL_PANEL
TEMPLATE_TEXT_PANEL
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model Relation
API Enumeration description of Relation
Name Description
OWNER
CONSTRUCTOR
DEMOLISHER
PERMITTER
SENDER
RECEIVER
NETOWNER
BORDER_A
BORDER_B
BUILDING
WEATHER
PARENT
RESULT_PARENT
CONTENT
Api Model TemplateExcelPanel
API Model description of TemplateExcelPanel
attribute String
autoApplied boolean
calcTimeMS long
contentID int
height double
id int
layoutX double
layoutY double
mapLink MapLink Maplink
name String
parentID int
point Point Point
relation Relation Relation
text String
updateTiming Timing
useOwner boolean
version int
warnings String
width double
Api Model TemplateTextPanel
API Model description of TemplateTextPanel
attribute String
autoApplied boolean
calcTimeMS long
contentID int
height double
id int
layoutX double
layoutY double
name String
parentID int
point Point Point
text String
updateTiming Timing
useOwner boolean
version int
warnings String
width double
Api Model TextPanel
API Model description of TextPanel
calcTimeMS long
contentID int
height double
id int
layoutX double
layoutY double
name String
parentID int
point Point Point
text String
updateTiming Timing
version int
warnings String
width double
Api Model Timing
API Enumeration description of Timing
Name Description
BEFORE
AFTER
Api Model WebPanel
API Model description of WebPanel
height double
id int
layoutX double
layoutY double
name String
point Point Point
url String
version int
width double
