Api session items netlines
API Endpoint: /api/session/items/netlines/
Edit items with events described at Api session event editor netline.
Default Query:
https://engine.tygron.com/api/session/items/netlines/?f=JSON&token=API_TOKENExample Response:
"attributes" : null,
"endNodeID" : 1,
"functionID" : 0,
"id" : 0,
"maquetteOverride" : null,
"name" : "NetLine 0",
"sourceIDs" : [ ],
"startNodeID" : 0,
"version" : 21
"endNodeID" : 58,
"functionID" : 0,
"id" : 1,
"name" : "NetLine 1",
"sourceIDs" : [ ],
"startNodeID" : 35,
"version" : 22
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/netlines/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/netlines/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/netlines/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/netlines/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/netlines/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/netlines/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/net_lines-foo/?crs=3857&token=API_TOKENGet Queries
attributes:
https://engine.tygron.com/api/session/items/netlines/attributes/?token=API_TOKENmax version:
https://engine.tygron.com/api/session/items/netlines/version/?token=API_TOKENcount:
https://engine.tygron.com/api/session/items/netlines/count/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/netlines/?f=HTML&token=API_TOKEN&crs=3857JSON:
https://engine.tygron.com/api/session/items/netlines/?f=JSON&token=API_TOKEN&crs=3857GEOJSON:
https://engine.tygron.com/api/session/items/netlines/?f=GEOJSON&token=API_TOKEN&crs=3857GPKG:
https://engine.tygron.com/api/session/items/netlines/?f=GPKG&token=API_TOKEN&crs=3857DXF:
https://engine.tygron.com/api/session/items/netlines/?f=DXF&token=API_TOKEN&crs=3857CSV:
https://engine.tygron.com/api/session/items/netlines/?f=CSV&token=API_TOKEN&crs=3857SSV:
https://engine.tygron.com/api/session/items/netlines/?f=SSV&token=API_TOKEN&crs=3857SMILE:
https://engine.tygron.com/api/session/items/netlines/?f=SMILE&token=API_TOKEN&crs=3857ZIPJSON:
https://engine.tygron.com/api/session/items/netlines/?f=ZIPJSON&token=API_TOKEN&crs=3857ZIPSMILE:
https://engine.tygron.com/api/session/items/netlines/?f=ZIPSMILE&token=API_TOKEN&crs=3857Api Model NetLine
API Model description of NetLine
| Name | Type | Description |
| attributes | Map<String,double[]> | |
| endNodeID | int | Net Node ID |
| functionID | int | Net Function ID |
| id | int | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| sourceIDs | int[] | Sources ID |
| startNodeID | int | Net Node ID |
| version | int |
