Api session event editor netline remove repeated
Revision as of 09:59, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetline/remove_repeated/
Description: Remove Net Lines and optionally remove connected Net Nodes linked to only one other Net Line of the same Net Type.
0 REQUIRED (NET_LINE Integer ID or multiple integer values in array [1, 2, 3]) Net Line IDs
1 REQUIRED (true, false) Is repeated removal true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetline/remove_repeated/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetline/remove_repeated/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/remove_repeated/", options)
