How to import data from ArcGIS Online
Revision as of 14:14, 10 July 2026 by Frank@tygron.nl (talk | contribs)
How to log in an ArcGIS Online account in the Tygron Client Application:
  1. Click on the Community tab and click on Sign in with ArcGIS
  2. In the new panel that pops up, choose Default ArcGIS Online and click on Continue to login
  3. Fill in your username and password
  4. Upon success, a confirmation message appears and the panel closes automatically.
  5. To add private or organizational data, see the instructions below.
How to import data from ArcGIS Online:
  1. Make sure you are logged in to either ArcGIS Online or ArcGIS Enterprise portal. See above for the steps.
  2. Select Current Situation in the ribbon bar
  3. Open the Geo Data Wizard and select the type of data you want to import.
  4. Select Catalogue service as the import method.
  5. Select Catalogue service ArcGIS Online (also to access the Enterprise portal data).
  6. In step 1.2 you can browse through your Esri content, Esri organization content and Esri open data. Select the data you want to import and click Next. In step 1.3 you can choose the layer you want to import. Proceed with the wizard.
  • In Select Catalog step of the Geo Data Wizard, datasets that are listed in ArcGIS Online or in the ArcGIS Enterprise portal with an extent which is not in your project location are not visible.
  • In the Select Service step of the Geo Data Wizard, if the dataset you want to import is not in the same location as your project, the data cannot be imported.
