Project map
The project map is the rectangular data space of your project. It is defined by a width and a height. Its location is defined by a world reference point, which is a coordinate relative to the EPSG:3857 WGS 84 / Pseudo-Mercator coordinate system.
The width and height are stored in the MAP_SIZE_M Setting item as an array of two integers. The world reference point is stored in the WORLD_REFERENCE_POINT Setting item as an array of two Doubles, representing X and Y.
When a project is generated, or new features are imported or drawn in a session, they are required to intersect with the project map. Only their intersection with this project map is imported. This holds for practically all items, with the exception of Height Sectors and Terrains.
Surrounding Map Bounds
Zooming out reveals a region surrounding the project map containing satellite images, height sector information, and terrain data. This provides better orientation and a visually cleaner project boundary.
The surrounding map extent is stored as a Setting, SURROUNDING_MAP_EXTEND_M, which defines the extra boundary distances around the project map. Its total dimensions are calculated as:
- are the dimensions of the surrounding map extents.
- are the configured distances around the project map, stored in the setting SURROUNDING_MAP_EXTEND_M.
- are the project map dimensions, stored in the setting MAP_SIZE_M.
