Oxidation formula (Subsidence Overlay)
Revision as of 11:36, 7 July 2026 by Frank@tygron.nl (talk | contribs)
This functionality is deprecated and will be removed in the future.
SO=aydgw,y,cbdct,cc
where
SO is the subsidence due to oxidation.
dgw,y,c is the calculated ground water depth for year y in cell c.
ay is the calculated a parameter value for the current year y.
dct,c is the clay thickness of the terrain in cell c, defined by CLAY_THICKNESS
b is the b parameter value, defined by the model attribute B
c is the c parameter value, defined by the model attribute C
Experts derived this formula empirically.
