How to add and remove Buildings to a measure
Revision as of 10:04, 6 July 2026 by Frank@tygron.nl (talk | contribs) (Created page with " {{howto|title=How to add a Building to a Measure |Open a project in the editor. |Select Future Design in the ribbon bar. |Click on ''Measures'' in the ribbon bar. |Select the Measure you want to add a Building to. |Click on 'Add Building' in the Measure Overview left panel }} {{howto|title=How to remove a Building from a Measure |Open a project in the editor. |Select Future Design in the ribbon bar. |Click on ''Measures'' in the ribbon bar. |Se...")
How to How to add a Building to a Measure:
  1. Open a project in the editor.
  2. Select Future Design in the ribbon bar.
  3. Click on Measures in the ribbon bar.
  4. Select the Measure you want to add a Building to.
  5. Click on 'Add Building' in the Measure Overview left panel
How to How to remove a Building from a Measure:
  4. Select the Building(s) of the Measure you want to remove.
  5. Click on 'Remove' in the Measure Overview left panel
  6. Confirm the removal in the dialog window.
  • Click on the 'Add Section' button to add a Section to a selected Building of a Measure.
API Endpoints
