Api session items overlays
Revision as of 07:44, 22 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/overlays/
Edit items with events described at Api session event editor overlay.
Default Query:
https://engine.tygron.com/api/session/items/overlays/?f=JSON&token=API_TOKEN
Example Response:
  "active" : true,
  "attributes" : {
    "CALC_TIME_MS" : [ 0.0 ]
  "calcTimeMS" : 6,
  "colorMultiplier" : 1.0,
  "colorOffset" : 127,
  "customLegend" : false,
  "diffLegend" : [ ],
  "id" : 3,
  "imageName" : "heightmap.png",
  "imageVersion" : 0,
  "inActiveCellSize" : null,
  "inActiveTimeframes" : null,
  "keys" : { },
  "legend" : [ {
    "color" : {
      "argb" : -13696641
    "entryName" : "32,1",
    "id" : 1,
    "value" : 32.122
    "color" : {
      "argb" : -16312961
    "entryName" : "34",
    "id" : 2,
    "value" : 33.987503
    "color" : {
      "argb" : -15122305
    "entryName" : "35,9",
    "id" : 3,
    "value" : 35.853
    "color" : {
      "argb" : -14719873
    "entryName" : "37,7",
    "id" : 4,
    "value" : 37.718502
    "color" : {
      "argb" : -13794421
    "entryName" : "39,6",
    "id" : 5,
    "value" : 39.584
    "color" : {
      "argb" : -12934235
    "entryName" : "41,4",
    "id" : 6,
    "value" : 41.4495
    "color" : {
      "argb" : -13467809
    "entryName" : "43,3",
    "id" : 7,
    "value" : 43.315002
    "color" : {
      "argb" : -10641847
    "entryName" : "45,2",
    "id" : 8,
    "value" : 45.1805
    "color" : {
      "argb" : -6169541
    "entryName" : "47",
    "id" : 9,
    "value" : 47.046
    "color" : {
      "argb" : -6437109
    "entryName" : "48,9",
    "id" : 10,
    "value" : 48.9115
    "color" : {
      "argb" : -4013540
    "entryName" : "50,8",
    "id" : 11,
    "value" : 50.777
    "color" : {
      "argb" : -2367897
    "entryName" : "52,6",
    "id" : 12,
    "value" : 52.6425
    "color" : {
      "argb" : -3366313
    "entryName" : "54,5",
    "id" : 13,
    "value" : 54.508
    "color" : {
      "argb" : -1530502
    "entryName" : "56,4",
    "id" : 14,
    "value" : 56.3735
    "color" : {
      "argb" : -2199968
    "entryName" : "58,2",
    "id" : 15,
    "value" : 58.239
    "color" : {
      "argb" : -2148303
    "entryName" : "60,1",
    "id" : 16,
    "value" : 60.1045
    "color" : {
      "argb" : -7467510
    "entryName" : "62",
    "id" : 17,
    "value" : 61.97
    "color" : {
      "argb" : -9493727
    "entryName" : "63,8",
    "id" : 18,
    "value" : 63.8355
    "color" : {
      "argb" : -9481646
    "entryName" : "65,7",
    "id" : 19,
    "value" : 65.701
    "color" : {
      "argb" : -3947581
    "entryName" : "67,6",
    "id" : 20,
    "value" : 67.5665
  "maquetteOverride" : null,
  "maxValue" : [ 0.0, 69.432, 0.0, 1.0 ],
  "minValue" : [ 0.0, 32.122, 0.0, 0.0 ],
  "name" : "Height Map",
  "parentID" : -1,
  "prequels" : { },
  "resultType" : "DSM",
  "showDifference" : false,
  "sortIndex" : 50,
  "type" : "HEIGHTMAP",
  "version" : 167,
  "visible" : true,
  "warnings" : ""
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/overlays/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/overlays/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/overlays/size/?token=API_TOKEN
Overlays (GeoJSON):
https://engine.tygron.com/web/overlays.geojson?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/overlays/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/overlays/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/overlays/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/overlays/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/overlays/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/overlays/?f=ZIPSMILE&token=API_TOKEN
Api Model AreaOverlay
API Model description of AreaOverlay
Name Type Description
areaIDs int[] Areas ID
attributes Map<String,double[]>
colorMultiplier double
colorOffset int
customLegend boolean
id int
imageName String
imageVersion int
legend LegendEntry[]
maquetteOverride Map<String,double[]>
name String
parentID int Overlay ID
remainderColor TColor Color
sortIndex int
type OverlayType Overlay Type
version int
visible boolean
Api Model AttributeOverlay
API Model description of AttributeOverlay
attribute String
attributeColor TColor Color
colorAttribute String
colorOffset int
id int
imageName String
imageVersion int
mapLink MapLink Maplink
name String
restColor TColor Color
sortIndex int
version int
visible boolean
Api Model AvgOverlay
API Model description of AvgOverlay
active boolean
calcTimeMS long
colorOffset int
diffLegend LegendEntry[]
id int
imageName String
imageVersion int
inActiveCellSize double
inActiveTimeframes int
keys Map<String,String>
layerMapLink MapLink Maplink
maxValue float[]
minValue float[]
name String
prequels Map<String,PrequelLink>
rasterization Rasterization
resultType String
showDifference boolean
sortIndex int
version int
visible boolean
warnings String
Api Model ComboOverlay
API Model description of ComboOverlay
active boolean
calcTimeMS long
colorOffset int
formula String
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model DefaultOverlay
API Model description of DefaultOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model DefaultRasterizationOverlay
API Model description of DefaultRasterizationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model DischargeMethod
API Enumeration description of DischargeMethod
Name Description
HEIGHT_MINIMA
WATER_TERRAINS
AREAS
Api Model DistanceOverlay
API Model description of DistanceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model FloodingOverlay
API Model description of FloodingOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
version int
visible boolean
warnings String
weatherID int Weather ID
Api Model FunctionOverlay
API Model description of FunctionOverlay
colorOffset int
functionIDs int[] Functions ID
functionsColor TColor Color
id int
imageName String
imageVersion int
name String
sortIndex int
version int
visible boolean
Api Model GeoTiffOverlay
API Model description of GeoTiffOverlay
active boolean
calcTimeMS long
colorOffset int
geoTiffIDs int[] Geo Tiffs ID
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model GridOverlay
API Model description of GridOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model GroundwaterOverlay
API Model description of GroundwaterOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
version int
visible boolean
warnings String
Api Model HeatModel
API Enumeration description of HeatModel
Name Description
UNESCO
DPRA
Api Model HeatOverlay
API Model description of HeatOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
model HeatModel
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model HeightOverlay
API Model description of HeightOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model ImageOverlay
API Model description of ImageOverlay
colorOffset int
id int
imageName String
imageNames String[]
imageVersion int
name String
sortIndex int
version int
visible boolean
Api Model InferenceOverlay
API Model description of InferenceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
neuralNetworkID int Neural Network ID
resultType String
sortIndex int
tensorLinks TensorLink[]
version int
visible boolean
warnings String
Api Model IterationOverlay
API Model description of IterationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model LegendEntry
API Model description of LegendEntry
color TColor Color
entryName String
id int
value float
Api Model Mode
API Enumeration description of Mode
Name Description
SPEED
AVERAGE
ACCURACY
Api Model NO2Overlay
API Model description of NO2Overlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model NetOverlay
API Model description of NetOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
netType NetType Net Type
showActive boolean
showNetwork boolean
sortIndex int
version int
visible boolean
Api Model NetType
API Enumeration description of NetType
Name Description
ELECTRICITY
GAS
HEAT
INTERNET
SEWER
Api Model NoiseOverlay
API Model description of NoiseOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model Overlay
API Model description of Overlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
version int
visible boolean
Api Model OverlayType
API Enumeration description of OverlayType
Name Description
OWNERSHIP
OWNERSHIP_GRID
ZIP_CODES
ZONING
NEIGHBORHOODS
MUNICIPALITIES
SCENARIO
VACANCY
HEAT_STRESS
SHADOW
TRAFFIC_DENSITY
TRAFFIC_NO2
TRAFFIC_NOISE
LIVABILITY
AERIUS
RAINFALL
FLOODING
GROUNDWATER
WATERSHED
SUBSIDENCE
WATERWIJZER
AVG
COMBO
DISTANCE
SIGHT_DISTANCE
TRAVEL_DISTANCE
INFERENCE
ITERATION
GEO_TIFF
WMS
WCS
AREA
ATTRIBUTE
FUNCTION
SATELLITE
HEIGHTMAP
UNDERGROUND
SOURCE
NETWORK_OWNERSHIP
NETWORK_OVERVIEW
NETWORK_DISTANCE
RESULT_CHILD
TEST
DISTURBANCE_DISTANCE
SAFETY_DISTANCE
DEPRECATED
Api Model RainOverlay
API Model description of RainOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
version int
visible boolean
warnings String
Api Model Rasterization
API Enumeration description of Rasterization
Name Description
FIRST
MIN
MAX
SINGLE_LAYER
GRID
Api Model RasterizationOverlay
API Model description of RasterizationOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model ResultChildOverlay
API Model description of ResultChildOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model ResultParentOverlay
API Model description of ResultParentOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model SatelliteOverlay
API Model description of SatelliteOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model ServiceOverlay
API Model description of ServiceOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
sourceID int Source ID
version int
visible boolean
warnings String
Api Model ShadowOverlay
API Model description of ShadowOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model SourceOverlay
API Model description of SourceOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
sources Map<int,int>
version int
visible boolean
Api Model TColor
API Model description of TColor
API Model description of TensorLink
coordinate int[]
id int
normalized boolean
prequel String
result String
tensorName String
valueType ValueType
Api Model TrafficDensityOverlay
API Model description of TrafficDensityOverlay
colorOffset int
id int
imageName String
imageVersion int
name String
sortIndex int
version int
visible boolean
Api Model TrafficOverlay
API Model description of TrafficOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model TravelDistanceOverlay
API Model description of TravelDistanceOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model ValueType
API Enumeration description of ValueType
Name Description
DEFAULT
R
G
B
A
Api Model WCSOverlay
API Model description of WCSOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model WMSOverlay
API Model description of WMSOverlay
active boolean
calcTimeMS long
colorOffset int
crs String
forceXY boolean
id int
imageName String
imageVersion int
layerName String
layerNames String[]
maxValue float[]
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
Api Model WaterOverlay
API Model description of WaterOverlay
active boolean
calcInfo String
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
minValue float[]
mode Mode
name String
resultType String
showAreas boolean
showSystem boolean
sortIndex int
version int
visible boolean
warnings String
Api Model WatershedOverlay
API Model description of WatershedOverlay
active boolean
calcTimeMS long
colorOffset int
id int
imageName String
imageVersion int
maxValue float[]
method DischargeMethod
minValue float[]
name String
resultType String
sortIndex int
version int
visible boolean
warnings String
