Api session items netloads
Revision as of 07:43, 22 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/netloads/
Edit items with events described at Api session event editor netload.
Default Query:
https://engine.tygron.com/api/session/items/netloads/?f=JSON&token=API_TOKEN
Example Response:
  "addressIDs" : [ ],
  "attributes" : {
    "ROOT_LOAD" : [ 1.0 ]
  "buildingID" : -1,
  "clusterID" : -1,
  "connectionState" : "NOTHING",
  "id" : 0,
  "maquetteOverride" : null,
  "name" : "NetLoad 0",
  "netType" : "ELECTRICITY",
  "nodeID" : 0,
  "point" : null,
  "sourceIDs" : [ ],
  "version" : 61
  "addressIDs" : [ 90 ],
  "attributes" : {
    "TYPE" : [ 5.0 ]
  "buildingID" : 444,
  "clusterID" : 0,
  "id" : 1,
  "name" : "NetLoad 1",
  "nodeID" : 2,
  "point" : null,
  "sourceIDs" : [ 12 ],
  "version" : 62
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/netloads/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/netloads/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/netloads/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/netloads/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/netloads/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/netloads/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/net_loads-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/netloads/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/netloads/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/netloads/?f=HTML&token=API_TOKEN&crs=3857
JSON:
https://engine.tygron.com/api/session/items/netloads/?f=JSON&token=API_TOKEN&crs=3857
GEOJSON:
https://engine.tygron.com/api/session/items/netloads/?f=GEOJSON&token=API_TOKEN&crs=3857
GPKG:
https://engine.tygron.com/api/session/items/netloads/?f=GPKG&token=API_TOKEN&crs=3857
DXF:
https://engine.tygron.com/api/session/items/netloads/?f=DXF&token=API_TOKEN&crs=3857
CSV:
https://engine.tygron.com/api/session/items/netloads/?f=CSV&token=API_TOKEN&crs=3857
SSV:
https://engine.tygron.com/api/session/items/netloads/?f=SSV&token=API_TOKEN&crs=3857
SMILE:
https://engine.tygron.com/api/session/items/netloads/?f=SMILE&token=API_TOKEN&crs=3857
ZIPJSON:
https://engine.tygron.com/api/session/items/netloads/?f=ZIPJSON&token=API_TOKEN&crs=3857
ZIPSMILE:
https://engine.tygron.com/api/session/items/netloads/?f=ZIPSMILE&token=API_TOKEN&crs=3857
Api Model NetLoad
API Model description of NetLoad
Name Type Description
addressIDs int[] Addresses ID
attributes Map<String,double[]>
buildingID int Building ID
clusterID int Net Cluster ID
connectionState TimeState Timestate
id int
maquetteOverride Map<String,double[]>
name String
netType NetType Net Type
nodeID int Net Node ID
point Point Point
sourceIDs int[] Sources ID
version int
Api Model NetType
API Enumeration description of NetType
Name Description
ELECTRICITY
GAS
HEAT
INTERNET
SEWER
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model TimeState
API Enumeration description of TimeState
Name Description
NOTHING
WAITING_FOR_DATE
REQUEST_PLOT_OWNER_APPROVAL
REQUEST_ZONING_APPROVAL
REQUEST_CONSTRUCTION_APPROVAL
CONSTRUCTION_APPROVED
CONSTRUCTION_DENIED
PENDING_CONSTRUCTION
CONSTRUCTING
READY
PENDING_UPGRADE
WAITING_FOR_DEMOLISH_DATE
REQUEST_DEMOLISH_ZONING_APPROVAL
REQUEST_DEMOLISH_APPROVAL
DEMOLISH_APPROVED
DEMOLISH_DENIED
PENDING_DEMOLISHING
DEMOLISHING
DEMOLISH_FINISHED
