Api session items indicators
API Endpoint: /api/session/items/indicators/
Edit items with events described at Api session event editor indicator.
Default Query:
https://engine.tygron.com/api/session/items/indicators/?f=JSON&token=API_TOKENExample Response:
"absolute" : true,
"attributes" : null,
"calcTimeMS" : 0,
"currentExplanation" : "Simple dummy Indicator",
"description" : "",
"exactNumberValues" : { },
"exactTextValues" : { },
"excelID" : 12,
"id" : 0,
"imageName" : "excel.png",
"imageVersion" : 0,
"isActive" : true,
"mapTypeValues" : {
"MAQUETTE" : 0.0,
"CURRENT" : 0.0
"maquetteExplanation" : "",
"maquetteOverride" : null,
"name" : "Indicator",
"parentID" : -1,
"shortName" : "Indicator",
"sortIndex" : 51,
"stakeholderID" : -1,
"targetDescriptions" : [ ],
"targets" : { },
"updateTiming" : "BEFORE",
"version" : 17,
"warnings" : ""
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/indicators/?version=100&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/indicators/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/indicators/size/?token=API_TOKENIndicators (GeoJSON):
https://engine.tygron.com/web/indicators.geojson?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/indicators/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/indicators/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/indicators/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/indicators/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/indicators/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/indicators/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/indicators/?f=ZIPSMILE&token=API_TOKENApi Model Indicator
API Model description of Indicator
| Name | Type | Description |
| absolute | boolean | |
| attributes | Map<String,double[]> | |
| calcTimeMS | long | |
| currentExplanation | String | |
| description | String | |
| exactNumberValues | Map<MapType,double> | Map<Map Type,double> |
| exactTextValues | Map<MapType,String> | Map<Map Type,String> |
| excelID | int | Excel Sheet ID |
| excelUpdated | boolean | |
| id | int | |
| imageName | String | |
| imageVersion | int | |
| isActive | boolean | |
| mapTypeValues | Map<MapType,double> | Map<Map Type,double> |
| maquetteExplanation | String | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| parentID | int | Indicator ID |
| shortName | String | |
| sortIndex | int | |
| stakeholderID | int | Stakeholder ID |
| targetDescriptions | String[] | |
| targets | Map<int,double[]> | |
| updateTiming | Timing | |
| version | int | |
| warnings | String |
Api Model MapType
API Enumeration description of MapType
| Name | Description |
| CURRENT | |
| MAQUETTE |
Api Model Timing
API Enumeration description of Timing
| BEFORE | |
| AFTER |
