Api session event participant map levee
API Endpoint: api/session/event/participant/map_levee/
Description: Create a Levee with a given height and Area.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder ID | |
| 1 | REQUIRED | (LEVEE Integer ID) | Levee ID | |
| 2 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | MultiPolygon describing the surface area | |
| 3 | REQUIRED | (Floating point number) | Height in meters | |
| 4 | REQUIRED | (Floating point number) | Angle in degrees | |
| 5 | REQUIRED | (true, false) | Is height relative | true or false |
| 200 | Integer (Action Log ID) |
curl 'https://engine.tygron.com/api/session/event/participant/map_levee/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 88, 94, true ]
'Curl example multi item POST
[ 1, 1, {
}, 19, 38, true ]
'JavaScript example POST
body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 88, 94, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/map_levee/?crs=3857", options)
