Api session event logic measurement line add
API Endpoint: api/session/event/logic/measurement_line_add/
Description: Add a LineMeasurement for an Overlay for a specific Timeframe.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) | Overlay IDs | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point start | |
| 2 | REQUIRED | (Point with crs: EPSG:3857) | Point end | |
| 3 | REQUIRED | (String) | Name | |
| 4 | REQUIRED | (Integer number) | Timeframe (-1 for automatic last) | |
| 5 | REQUIRED | (true, false) | Save Measurement | true or false |
| 6 | REQUIRED | (true, false) | Sum | true or false |
| 200 | Integer (Measurement ID) |
curl 'https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658797.650397124, 6799437.237235598 ]
"type" : "Point",
"coordinates" : [ 658728.9234541768, 6799301.930376602 ]
}, "Name", -1, true, true ]
'Curl example multi item POST
[ [ 1, 2, 3 ], {
"type" : "Point",
"coordinates" : [ 658699.9212559488, 6799332.816021241 ]
"type" : "Point",
"coordinates" : [ 658669.0756632545, 6799449.0804085815 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658797.650397124, 6799437.237235598 ]}, { "type" : "Point", "coordinates" : [ 658728.9234541768, 6799301.930376602 ]}, "Name", -1, true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857", options)
