Api session event editor specialeffect set location
Revision as of 13:02, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorspecialeffect/set_location/
Description: Set Location
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effects
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658652.0579652631, 6799418.043276475 ]
Curl example multi item POST
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658713.7036748413, 6799426.068093414 ]
JavaScript example POST
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658652.0579652631, 6799418.043276475 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857", options)
