Api session event editor netload set point
API Endpoint: api/session/event/editornetload/set_point/
Description: Set Point
| 0 | REQUIRED | (NET_LOAD Integer ID) | Net Loads | |
| 1 | OPTIONAL | (Point with crs: EPSG:3857) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetload/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_point/?crs=3857", options)
