Api session event editor building query
Revision as of 13:00, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/query/
Description: Executes a single TQL Query. Note: you can also use the Session/query endpoint to execute multiple statements and get additional information on API usage.
0 REQUIRED (String) TQL Query Statement
1 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value for update queries (optional)
200 Object (Object)
curl 'https://engine.tygron.com/api/session/event/editorbuilding/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TQL Query Statement"'
JavaScript example POST
 body: '"TQL Query Statement"'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/query/", options)
