Api session event editor address set point
API Endpoint: api/session/event/editoraddress/set_point/
Description: Set the Point of an Address
| 0 | REQUIRED | (ADDRESSE Integer ID or multiple integer values in array [1, 2, 3]) | Address ID | |
| 1 | REQUIRED | (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) | Point |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658793.9554875104, 6799417.057431265 ]
'Curl example multi item POST
[ [ 1, 2, 3 ], [ {
"type" : "Point",
"coordinates" : [ 658727.4617316923, 6799332.031576055 ]
"type" : "Point",
"coordinates" : [ 658792.0617448251, 6799455.583441816 ]
"type" : "Point",
"coordinates" : [ 658681.5717663605, 6799307.559523016 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658793.9554875104, 6799417.057431265 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
