Api session event logic measurement line add
API Endpoint: api/session/event/logic/measurement_line_add/
Description: Add a LineMeasurement for an Overlay for a specific Timeframe.
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlay IDs
1 REQUIRED (Point with crs: EPSG:3857) Point start
2 REQUIRED (Point with crs: EPSG:3857) Point end
3 REQUIRED (String) Name
4 REQUIRED (Integer number) Timeframe (-1 for automatic last)
5 REQUIRED (true, false) Save Measurement true or false
6 REQUIRED (true, false) Sum true or false
200 Integer (Measurement ID)
curl 'https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658761.808961805, 6799329.467106712 ]
 "type" : "Point",
 "coordinates" : [ 658720.5591532934, 6799414.89571839 ]
}, "Name", -1, true, true ]
Curl example multi item POST
[ [ 1, 2, 3 ], {
 "type" : "Point",
 "coordinates" : [ 658775.5946289696, 6799332.695837088 ]
 "type" : "Point",
 "coordinates" : [ 658646.2029546449, 6799419.519608317 ]
JavaScript example POST
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658761.808961805, 6799329.467106712 ]}, { "type" : "Point", "coordinates" : [ 658720.5591532934, 6799414.89571839 ]}, "Name", -1, true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857", options)
