How to remove an Area
Revision as of 09:48, 16 June 2026 by Maxim@tygron.com (talk | contribs)
Editor → Current Situation (Ribbon tab) → Areas (Ribbon bar)
To remove an area, select an area in the left panel, and select "Remove" at the bottom of the panel.
How to remove an area:
  1. Select "Areas" in the ribbon bar.
  2. Select the area you wish to remove.
  3. Select "Remove" in the left panel.
