Api session event participant map levee
API Endpoint: api/session/event/participant/map_levee/
Description: Create a Levee with a given height and Area.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (LEVEE Integer ID) Levee ID
2 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon describing the surface Area
3 REQUIRED (Floating point number) Height in meters
4 REQUIRED (Floating point number) Angle in degrees
5 REQUIRED (true, false) Is height relative true or false
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/map_levee/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 5, 98, true ]
Curl example multi item POST
[ 1, 1, {
}, 88, 3, true ]
JavaScript example POST
 body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 5, 98, true ]'
fetch("https://engine.tygron.com/api/session/event/participant/map_levee/?crs=3857", options)
