Api session event logic special effect set active
Revision as of 12:08, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/special_effect_set_active/
Description: Activate/deactivate a Special Effect.
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect ID
1 REQUIRED (true, false) Activated true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/special_effect_set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/special_effect_set_active/", options)
