Api session event editor setting set import crs
API Endpoint: api/session/event/editorsetting/set_import_crs/
Description: Set Import Crs
| 0 | REQUIRED | (String) | String |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_import_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text"'JavaScript example POST
body: '"Text"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_import_crs/", options)
