Api session event editor scenario add event
Revision as of 12:06, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorscenario/add_event/
Description: Add empty dummy event that is Triggered on Scenario activation.
0 REQUIRED (SCENARIO Integer ID) Scenario ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/add_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorscenario/add_event/", options)
