Api session event editor parametric add example
Revision as of 12:05, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorparametric/add_example/
Description: Add Example
0 REQUIRED (Enumeration) Example CITY_NEIGHBORHOOD, SUBURBAN_NEIGHBORHOOD, URBAN_NEIGHBORHOOD or WINDMILL_AREA
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorparametric/add_example/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"CITY_NEIGHBORHOOD"'
JavaScript example POST
 body: '"CITY_NEIGHBORHOOD"'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add_example/", options)
