Api session event editor panel remove overlay
API Endpoint: api/session/event/editorpanel/remove_overlay/
Description: Remove Overlay
| 0 | REQUIRED | (PANEL Integer ID) | Panels |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/remove_overlay/", options)
