Api session event editor panel export excel call tree
API Endpoint: api/session/event/editorpanel/export_excel_call_tree/
Description: Export Excel Sheet Call Tree
| 0 | REQUIRED | (PANEL Integer ID) | Panels |
| 200 | byte[] (byte array) |
curl 'https://engine.tygron.com/api/session/event/editorpanel/export_excel_call_tree/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/export_excel_call_tree/", options)
