Api session event editor indicator set stakeholder
Revision as of 12:03, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorindicator/set_stakeholder/
Description: Set Stakeholder
0 REQUIRED (INDICATOR Integer ID) Indicators
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_stakeholder/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_stakeholder/", options)
