Api session event editor indicator set excel
API Endpoint: api/session/event/editorindicator/set_excel/
Description: Set Excel Sheet
| 0 | REQUIRED | (INDICATOR Integer ID) | Indicators | |
| 1 | REQUIRED | (EXCEL_SHEET Integer ID) | Excel Sheets |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_excel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_excel/", options)
