Api session event editor geoplugin set source
API Endpoint: api/session/event/editorgeoplugin/set_source/
Description: Set Source
0 REQUIRED (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) Geo Plugins
1 REQUIRED (SOURCE Integer ID or multiple values in array [1, 2, 3]) Sources
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/set_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/set_source/", options)
