Api session event editor area generate border areas
API Endpoint: api/session/event/editorarea/generate_border_areas/
Description: Generate Border Areas
| 0 | REQUIRED | (String) | String | |
| 1 | REQUIRED | (String) | String | |
| 2 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text", 57 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text", 60 ]'JavaScript example POST
body: '[ "Text", "Text", 57 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/", options)
