Api session event editor address set point
API Endpoint: api/session/event/editoraddress/set_point/
Description: Set the Point of an Address
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address ID
1 REQUIRED (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658768.8642089966, 6799449.510803973 ]
Curl example multi item POST
[ [ 1, 2, 3 ], [ {
 "type" : "Point",
 "coordinates" : [ 658655.4150545691, 6799392.0654020775 ]
 "type" : "Point",
 "coordinates" : [ 658798.1668724018, 6799397.874888853 ]
 "type" : "Point",
 "coordinates" : [ 658709.2551660802, 6799449.077160313 ]
JavaScript example POST
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658768.8642089966, 6799449.510803973 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
