Api session items measures
API Endpoint: /api/session/items/measures/
Edit items with events described at Api session event editor measure.
Default Query:
https://engine.tygron.com/api/session/items/measures/?f=JSON&token=API_TOKENExample Response:
"actualHeightChangeM3" : null,
"buildingIDs" : [ 1405 ],
"buildingPermitProcessed" : null,
"center" : {
"type" : "Point",
"coordinates" : [ 659086.4055532492, 6799091.1227987455, 55.402 ]
"clientActionEvents" : { },
"confirmationsRequired" : false,
"constructionCostsFixed" : -1.0,
"constructionCostsM3" : 0.0,
"custom" : false,
"dependencyIDs" : [ ],
"description" : "",
"geoTiffSpatials" : [ ],
"gridSpatials" : [ ],
"id" : 0,
"imageName" : "measure.png",
"imageVersion" : 0,
"incomeFixed" : 0.0,
"landOwnerPermissions" : { },
"leveeSpatials" : [ ],
"name" : "Measure",
"ownerID" : 2,
"serverActionEvents" : { },
"sourceIDs" : [ ],
"state" : "NOTHING",
"terrainSpatials" : [ {
"id" : 1,
"innerHeight" : 49.559317009580646,
"innerPolygon" : {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 659142.0614489131, 6799231.181467466 ], [ 659142.7646998417, 6799263.655208195 ], [ 659061.5757606464, 6799265.410856503 ], [ 659060.8741338538, 6799232.937108732 ], [ 659142.0614489131, 6799231.181467466 ] ] ] ]
"measureEditType" : "WATER",
"outerPolygon" : {
"coordinates" : [ [ [ [ 659041.5063109348, 6799223.619708879 ], [ 659155.0675307526, 6799218.219617132 ], [ 659158.153389331, 6799283.110281363 ], [ 659044.592169513, 6799288.5104164 ], [ 659041.5063109348, 6799223.619708879 ] ] ] ]
"relative" : false,
"terrainTypeID" : 3
"id" : 2,
"innerHeight" : 0.0,
"innerPolygon" : {
"coordinates" : [ ]
"measureEditType" : "FLATTEN",
"outerPolygon" : {
"coordinates" : [ ]
"relative" : false,
"terrainTypeID" : 1
"upgradeSpatials" : [ ],
"version" : 4
"buildingIDs" : [ 1410, 1411, 1412, 1413, 1414, 1415, 1416, 1417, 1418, 1419 ],
"center" : {
"type" : "Point",
"coordinates" : [ 659256.3616506538, 6799141.129437042, 58.377 ]
"custom" : false,
"description" : "",
"id" : 1,
"imageVersion" : 0,
"name" : "Measure (2)",
"ownerID" : 2,
"sourceIDs" : [ ],
"terrainSpatials" : [ ],
"version" : 1
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/measures/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/measures/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/measures/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/measures/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/measures/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/measures/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/measures-foo/?crs=3857&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/measures/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/measures/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/measures/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/measures/?f=JSON&token=API_TOKENGEOJSON:
https://engine.tygron.com/api/session/items/measures/?f=GEOJSON&token=API_TOKENGPKG:
https://engine.tygron.com/api/session/items/measures/?f=GPKG&token=API_TOKENDXF:
https://engine.tygron.com/api/session/items/measures/?f=DXF&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/measures/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/measures/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/measures/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/measures/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/measures/?f=ZIPSMILE&token=API_TOKENApi Model ActionType
API Enumeration description of ActionType
| Name | Description |
| CONSTRUCTION_PLAN | |
| CONSTRUCTION_PLAN_CANCEL |
Api Model GeoTiffSpatial
API Model description of GeoTiffSpatial
| Name | Type | Description |
| autoMP | boolean | |
| geoTiffIDs | int[] | Geo Tiffs ID |
| id | int | |
| multiPolygon | MultiPolygon | MultiPolygon |
| terrainTypeID | int |
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model GridSpatial
API Model description of GridSpatial
| id | int | |
| overlayIDs | int[] | Overlays ID |
Api Model LeveeSpatial
API Model description of LeveeSpatial
| angleOverride | double | |
| heightOverride | double | |
| id | int | |
| isRelativeOverride | Boolean | |
| leveeID | int | Levee ID |
| sidePolygon | MultiPolygon | MultiPolygon |
| topPolygon | MultiPolygon | MultiPolygon |
Api Model LineString
API Model description of LineString
Api Model MapMeasure
API Model description of MapMeasure
| actualHeightChangeM3 | double | |
| buildingIDs | int[] | Buildings ID |
| buildingPermitProcessed | Set | |
| center | Point | Point |
| clientActionEvents | Map<ActionType,java.util.List<nl.tytech.data.core.item.CodedEvent>> | Map<ActionType,java.util.List<nl.tytech.data.core.Item.CodedEvent>> |
| confirmationsRequired | boolean | |
| constructionCostsFixed | double | |
| constructionCostsM3 | double | |
| custom | boolean | |
| dependencyIDs | int[] | Measures ID |
| description | String | |
| geoTiffSpatials | GeoTiffSpatial[] | GeoTIFFSpatial[] |
| gridSpatials | GridSpatial[] | GridSpatial[] |
| id | int | |
| imageName | String | |
| imageVersion | int | |
| incomeFixed | double | |
| landOwnerPermissions | Map<int,Boolean> | |
| leveeSpatials | LeveeSpatial[] | Leveespatial[] |
| name | String | |
| ownerID | int | Stakeholder ID |
| serverActionEvents | Map<ActionType,java.util.List<nl.tytech.data.core.item.CodedEvent>> | Map<ActionType,java.util.List<nl.tytech.data.core.Item.CodedEvent>> |
| sourceIDs | int[] | Sources ID |
| state | TimeState | Timestate |
| terrainSpatials | TerrainSpatial[] | Terrainspatial[] |
| upgradeSpatials | UpgradeSpatial[] | |
| version | int |
Api Model Measure
API Model description of Measure
| id | int | |
| name | String | |
| version | int |
Api Model MeasureEditType
API Enumeration description of MeasureEditType
| BUILDING | |
| RAISE | |
| FLATTEN | |
| WATER | |
| UPGRADE | |
| LEVEE | |
| GEOTIFF | |
| GRID |
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | MultiPolygon |
| coordinates | double[][][][] | array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
Api Model Point
API Model description of Point
| type | String | Point |
| coordinates | double[] | x, y, (optional) z |
Api Model TerrainSpatial
API Model description of TerrainSpatial
| id | int | |
| innerHeight | double | |
| innerPolygon | MultiPolygon | MultiPolygon |
| innerPrep | PreparedGeometry | |
| measureEditType | MeasureEditType | MeasureEditType |
| outerPolygon | MultiPolygon | MultiPolygon |
| outerPrep | PreparedGeometry | |
| outerRings | LineString[] | |
| relative | boolean | |
Api Model TimeState
API Enumeration description of TimeState
| NOTHING | |
| WAITING_FOR_DATE | |
| REQUEST_PLOT_OWNER_APPROVAL | |
| REQUEST_ZONING_APPROVAL | |
| REQUEST_CONSTRUCTION_APPROVAL | |
| CONSTRUCTION_APPROVED | |
| CONSTRUCTION_DENIED | |
| PENDING_CONSTRUCTION | |
| CONSTRUCTING | |
| READY | |
| PENDING_UPGRADE | |
| WAITING_FOR_DEMOLISH_DATE | |
| REQUEST_DEMOLISH_ZONING_APPROVAL | |
| REQUEST_DEMOLISH_APPROVAL | |
| DEMOLISH_APPROVED | |
| DEMOLISH_DENIED | |
| PENDING_DEMOLISHING | |
| DEMOLISHING | |
| DEMOLISH_FINISHED |
Api Model UpgradeSpatial
API Model description of UpgradeSpatial
| id | int | |
| upgradeID | int | Upgrade Type ID |
