Satellite map
Revision as of 15:54, 9 June 2026 by Maxim@tygron.com (talk | contribs)
Buildings on top of a height map with satellite images rendered upon it. Notice that certain parts of the satellite image are overwritten by Buildings and terrains present on those locations
The satellite map is a visual component rendered on top of the height map in the 3D Visualization.
Satellite images are obtained from WMS sources such as World Imagery and linked to Height Sectors.
When making changes to terrains in the project map, the visibility of the satellite image can be partially overridden by the adjusted terrain part.
Whether or not the satellite image is shown is determined by the showSatellite parameter in the Terrain item.
