Model attributes (Heat Stress Overlay)
Revision as of 09:49, 9 June 2026 by Frank@tygron.nl (talk | contribs)
The Heat Stress Overlay's model calculations depend on a number of calculation-wide parameters. These parameters are available as attributes of the Heat Stress Overlay and can be modified as such.
  • The model relies on a number of attributes which can be measured by measure stations. For any given project, it is recommended to find data from a (reference) weather station applicable to the project area, and use those values as parameters for the Heat Module calculations.
  • When the DATES attribute is configured for multiple timeframes, the Hourly, Sun, and Wind attributes should have an equal amount of entries. When using the Heat Stress Overlay configuration wizard, the necessary entries are created automatically.
