Api session event editor panel set size
API Endpoint: api/session/event/editorpanel/set_size/
Description: Set Size
0 REQUIRED (PANEL Integer ID) Panels
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 51, 0 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 20, 51 ]'
JavaScript example POST:
 body: '[ 1, 51, 0 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_size/", options)
