Api session event editor netload import
API Endpoint: api/session/event/editornetload/import/
Description: Import multiple Net Loads
0 REQUIRED (GeometryCollection with crs: EPSG:3857) GeometryCollection
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
2 REQUIRED (NetType or multiple values in array [a, b, c]) Net Type[]
3 REQUIRED (TimeState or multiple values in array [a, b, c]) Timestate[]
4 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
5 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
6 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) double[][]
7 REQUIRED (Integer number) Integer
8 REQUIRED (Floating point number) Double
9 REQUIRED (Floating point number) Double
10 REQUIRED (SOURCE Integer ID) Sources
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/import/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "Text 1", "ELECTRICITY", "NOTHING", "Text 1", "Text 1", [ 1.0, 2.0 ], 1, 23, 17, 1 ]
Curl example multi item POST:
 "geometries" : [ {
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ "Text 1", "Text 2", "Text 3" ], [ "ELECTRICITY", "GAS", "HEAT" ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ], [ "Text 1", "Text 2", "Text 3" ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], 1, 69, 51, 1 ]
JavaScript example POST:
 body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Text 1", "ELECTRICITY", "NOTHING", "Text 1", "Text 1", [ 1.0, 2.0 ], 1, 23, 17, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/import/?crs=3857", options)
